2.4GHz Whip Rubber Antenna
The 2.4 GHz whip antenna is a compact, omnidirectional high performance antenna for 2.4 GHz band including WiFi, ZigBee, Bluetooth, Video, ISM, etc.
- Whip antenna for 2.4Ghz with SMA male connector
- Same model included in several RF Explorer models
The 2.4 GHz whip antenna is a compact, omnidirectional high-performance antenna for 2.4 GHz band including WiFi, ZigBee, Bluetooth, Video, ISM, etc.
This antenna is included in several RF Explorer models such as 2.4G, ISM Combo, 3G Combo and 6G Combo. You can order this as a replacement if your original antenna got damaged or lost, or as an extra antenna for multiple purposes such as using it with RF Explorer Signal Generator.
- Impedance: 50 ohm
- Characterized response: 2400-2500Mhz
- VSWR: <1.8
- Gain: 2dBi
- Max power: 25W
- RoHS compliant
2.4GHz Whip Rubber Antenna X 1
Dimensions | 60mm x60mm x9mm |
Weight | G.W 6g |
HSCODE | 9030900090 |
USHSCODE | 8517180050 |
UPC | 841454115489 |
EUHSCODE | 9030900000 |
COO | CHINA |
RoHS | 1 |
