10.1 inch 1200x1920 HDMI IPS LCD Display
- 10+: $72.00
Note
By default config, this display does not support Raspberry Pi 4. Thanks to Marc, he successfully modified the pi 4 configuration file so that this screen can be used with the Raspberry Pi 4. For Pi 4 users, please check the Document Pi 4 config file.
Here we offer you this high-resolution, ultra-wide viewing angle IPS HDMI display. Specifically, this display has a resolution of 1200*1920 and a viewing angle up to double 178 degrees. It is small and light, easy to carry. No need for drivers. We tested it with raspberry pi 3b/3b+/4b and windows10.
In addition, this display has a backlight-adjustable function that allows you to adjust the brightness using the buttons on the back.
Tip
- In order to protect the screen, the screen surface comes with a protective film. If you want to tear off the protective film, you need to use a screwdriver to remove the screws on the outer casing.
- If you want to use Raspberry Pi with this display please check the documents and do a little bit configuration.
This series includes the following three products:
5 inch 720x1280 HDMI IPS LCD Display
7 inch 720x1280 HDMI IPS LCD Display
- Ultra-thin.
- High viewing angle.
- High resolution.
Usage
Assembly Drawing
You can also mount the Raspberry Pi onto the back of the screen:
For more detail about assembly, please check the DOCUMENTS TAB.
If you are willing to know more information about Raspberry Pi display, please view the table as follow.
Product name | Resolution | Power supply | Display interface | For use with | Dimension(mm) | Touch panel type | Display tec. |
5 inch 720x1280 HDMI IPS LCD Display | 720x1280 | 5V | HDMI2.0 | Raspberry Pi3, Windows, etc. | 134x84 | None | IPS |
5 inch 800x480 Capacitive TouchScreen | 800x480 | 5V | HDMI & USB 2.0 | Raspberry Pi3, Windows, etc. | 184x106x45 | Capacitive | TFT |
5 Inch HDMI Display with USB TouchScreen | 800x480 | 5V | HDMI & USB 2.0 | Raspberry Pi3, Windows, etc. | 170x90x40 | Resistive | TFT |
5 inch Capacitive touch screen & Acrylic Case Kit | 800x480 | 5V | HDMI & USB 2.0 | Raspberry Pi3, Windows, etc. | 210x150x50 | Capacitive | TFT |
7 inch 720x1280 HDMI IPS LCD Display | 720x1280 | 5V | HDMI2.0 | Raspberry Pi3, Windows, etc. | 192x118 | None | IPS |
Raspberry Pi 7 inch Touchscreen Display | 800x480 | 5V | Display ribbon cable | Raspberry Pi3, Pi2, Pi | 194x110x20 | Capacitive | TFT |
7 Inch 1024x600 Capacitive Touch Screen With Camera Kit | 1024x600 | 5V | HDMI & USB 2.0 | Raspberry Pi3, Windows, etc. | 177x113x15 | Capacitive | TFT |
10.1 inch 1200x1920 HDMI IPS LCD Display | 1200x1920 | 5V | HDMI2.0 | Raspberry Pi3, Pi4,Windows,etc. | 255x165 | None | IPS |
15.6 Inch 1920*1080 Full HD IPS Touch Screen Portable Monitor | 1920x1080 | 5V | Mini DP/ Mini HDMI / Type C | Raspberry Pi3,Pi4,Windows,etc. | 375x230x12 | Capacitive | IPS |
7 Inch HDMI 1280x800 IPS Display | 1280x800 | 7.5V~12V | AV + VGA + HDMI (HDMI 1.2) | Raspberry Pi3, Windows, etc. | 162x106x5 | None | IPS |
7 Inch 1024x600 Capacitive Touch Screen DIY Kit | 1024x600 | 5V | AV + VGA + HDMI (HDMI 1.2) | Raspberry Pi3, Windows, etc. | 265x165x50 | Capacitive | TFT |
10.1 Inch LCD Display - 1366x768 HDMI&VGA&NTSC&PAL | 1366x768 | 5V~24V | AV + VGA + HDMI (HDMI 1.2) | Raspberry Pi3,Pi4,Windows,etc. | 230x150x5 | None | TFT |
Raspberry Pi HDMI LCD (10.1 inch) | 1280x800 | 5V | HDMI & USB 2.0 | Raspberry Pi3,Pi4,Windows,etc. | 290x200x35 | Capacitive | IPS |
Dimension |
10.1 inch |
Resolution |
1200x1920 |
Refresh Rate |
60HZ |
Panel Type |
IPS panel (viewing angle double 178°) |
Power |
Micro usb standard interface |
Working Current |
5v 600mA |
Support Platform |
Paspberry Pi,Windows,etc. HDMI interface |
Interface |
HDMI2.0 (Compatible with HDMI1.4) |
Frame Material |
colorful acrylic plate |
Attachment |
HDMI2.0 cable, micro USB cable,Back bracket,raspberry pi mounting screws |
Features |
Ultra-thin, high viewing angle, high resolution |
Other Functions |
Backlight power switch, backlight brightness adjustment |
Part List | Number |
10.1 inch screen | 1 |
HDMI2.0 cable | 1 |
Micro USB cable | 1 |
Back bracket | 1 |
Raspberry pi mounting screws bag | 1 |
HSCODE | 8528521200 |
USHSCODE | 8531809051 |
EUHSCODE | 8531202090 |
COO | CHINA |
RoHS | 1 |
from order viewtricky to get started with raspberry pi
config for buster updateIf you have problems with this screen after updating a Raspberry Pi 3 Model B use this in your config.txt not tested with any other model.
disable_overscan=1
framebuffer_width=1920
framebuffer_height=1200
hdmi_group=2
hdmi_mode=87
hdmi_timings=1200 0 48 32 80 1920 0 3 10 42 0 0 0 60 0 161000000 0
display_rotate=3
max_framebuffer_width=1920
max_framebuffer_height=1920 -
Great image, clear displayThis is a good lil display. Works just fine for me. (Buttons and all) The protector was a bit to get off & the instructions not really provided for assembly. (Saves on the time for looking it up.) But other than that this LCD, works just fine for me.
Great image, but fatally flawedFirst the good:
The picture is beautiful. It's sharp, great color, excellent backlight.
But the display has issues. As others have reported, the buttons don't do anything.
My unit had serious problems being able to be powered on. There was no pattern. Sometimes it would come on right away when plugged in. Sometimes I'd have to unplug it a couple of times to get it to come on.
I tried numerous USB power supply sources. It worked a few times being powered through the HDMI cable from my Pi. But mostly it didn't. I'd get a display, but no backlight.
After a couple of days of futzing with it, now it won't power on at all.
Depending on the return policy here, it's going back, or it's going in the trash. Which is a shame. $80 is a lot to spend on a paperweight. -
Nice but has some flawsI purchased this display based on it's price, form factor, and features.
Leading with the cons, the display claims 3 buttons (power, increase brightness, decrease brightness); none of them work.
I now have two of these displays, and neither of them respond to button presses.
On the plus side, the "sandwich-style" frame is well designed and constructed, and the display is bright, crisp, and clear. The image quality is fine for my project.
For my project I decided that I could live with the failure of the buttons to function, but it would have been much better if the product was fully functional as advertised.
