Better connector for Electronic Bricks?
It’s reliable and of 2.54mm pitch, but we always found it too big to fit on smaller modules, and the DIP pin hinders smaller bricks. The accelerate-meter looks cuter sitting on the connector, but would you prefer a smaller SMT one?
We were brainstorming use some of our electronic brick sensors as alternative probe for DSO nano, quite a part of the sensors do the job and why don’t we just use 3.5mm audio jack as the electronic cable?  The cost would be much lower, since minions audio jacks are in current stock.
Though we are quite excited about this upgrade.  We are still worried about possible bridging between Vcc and GND. Some in-depth endurance test of this design is needed.
PROs:
  • Smaller
  • Compatible with DSO nano, Music Shield (why not record something other than audio?)
  • Widely available
  • Much Cheaper
Cons:
  • Possible shortage while plugging
  • not 2.54mm pitch
  • Other unknown issues
How do you think? 🙂
24 thoughts on "Better connector for Electronic Bricks?"
  1. 3.5mm round TRS connectors are noisy. Also if you leave one plugged in for a while it corrodes and you need to rotate the connector to fix it up.
  2. Another option you might have considered was standard RC servo headers. Cables and extensions are cheap, it’s 2.54 mm / 0.1″ spacing. The JR version is keyed.
    The only problem is that it’s not a locking connector, but I don’t mind that myself.
  3. I think TRRS is good, but the extension cables and adapters are much more expensive and harder to get.
    Oh, in the original post, you mention the desirability of keeping the 2.54 mm (0.1″) spacing. Is this still important to you?
    It’s not important to me, personally.
Comments are closed.
September 2010
6789101112
13141516171819
20212223242526
27282930
