Product Details
Wiki & Learn
Reviews
Download PDF
The Grove-SEN54 is a comprehensive solution for measuring essential air quality parameters including particulate matter, VOC, humidity, and temperature. Its advanced algorithms make integration into HVAC and Air Purifier systems effortless and providing a hassle-free experience for end-users without the need for any coding.
  • All-in-one enviromental sensor: providing accurate measurement of particulate matter, volatile organic compounds (VOCs), humidity and temperature.
  • Easy integration into various applications: the proprietary algorithms enable straightforward integration into Heating, Ventilation, Air Conditioning and Air Purifier
  • Adaptive algorithm: the STAR engine accelerates its response to ambient temperature which improves measurement accuracy and stability
  • Low power consumption: costs only 6.8 mA under RHT/Gas-Only Measurement Mode and 2.6 mA for Idle Mode
  • Superior sensing accuracy and lifetime: provide fully calibrated outputs with a digital interface and the high robustness enable fine performance for up to 10 years
Grove-all in one environmental sensor SEN54 powered is an integrated, superior Grove IIC ambient sensor, assembling PM, VOC, RH, Temperature sensing functionality, delivering up to 7 types of environmental data signal, sensing in high accuracy and operating for long terms, born for HVAC(Heating, Ventilation and Air Conditioning) and air quality long years detecting applications. Powered by Sensirion, it represents fine sensing performance, and there will be only one Grove cable needed between the sensor and the single board, such as Wio terminal, Seeeduino, Arduino expansion board, Raspberry Pi expansion board, and XIAO expansion board, as simplifying the edge in the wild.
The sensor is equipped with sensing components that can change the magnitude of the current corresponding to a specific gas to measure VOC(Volatile Organic Compounds), where applies the same principle to sense Temp(Temperature), RH(Relative Humidity). There is a laser generator and a filter on the sensor as it utilizes the laser scattering method to calculate the particle size of the gas passing the sensor for precise PM1.0, PM2.5, PM4, and PM10 detection. It will continuously output 7 signals above and the sampling interval will be just 1 second.
Based on the complex mathematical algorithm and model, the sensor has been designed to output calibrated digital signals to ensure superior sensing accuracy. Meanwhile, the sensing components on it possess high robustness which makes it cable of operating 24/7 for up to 10 years. There are three operating modes available for the user, which is helpful for edge deploying. It costs only 6.5 mA under RHT/Gas-Only Measurement Mode and 0.7 mA for Idle Mode while the full function of Measurement mode can be programmed to be set on or off through the IIC function.
Imagine you are in a poor air quality environment without knowing it, or you want a device that can detect harmful gases in real-time, that this device can be easily deployed and used, for a way long time applying. Then this Grove-all in one environmental sensor will be the amazed Grove for you.
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Application
  • Heating Ventilation and Air Conditioning
  • Air Quality Detection
  • Respiratory Healthcare
  • Harmful Gas Alarm
  • Particulate Matter Alert
  • Fire Alarm
  • Chemical Experiment
  • Smart Farm
Sensor Module Specifications
ParameterConditionsValueUnits
Sampling interval-1±0.03s
Lifetime24 h/day operation> 10years
Acoustic emission level0.2m24dB(A)
Long term acoustic emission level drift0.2m+0.5dB(A) / year
Particulate Matter Specifications
Mass concentration specified range 0 to 1'000μg/m3
Mass concentration size rangePM1.00.3 to 1.0μg
PM2.50.3 to 2.5μg
PM4 0.3 to 4.0μg
PM10 0.3 to 10.0μg
Temperature and Humidity Specifications
Compensated outputs-Temperature and Relative Humidity°C
%RH
Typical accuracy temperature@ 15-30 °C, 50 %RH
± 0.45
°C
Max. accuracy temperature@ 15-30 °C, 50 %RH± 0.7°C
Repeatability temperature@ 25 °C, 50 %RH, τ 63%< 60s
Gas Specifications
ParameterCommentsValuesUnits
MinTypMax
Output signals VOC Index1-500VOC Index points
Device-to-device variationVOC Index <±15  VOC Index points
RepeatabilityVOC Index <±5 VOC Index points
For further and more specific measured information, please refer to here.
Grove - all in one environmental sensor SEN54x1
Grove cablex1
Certification
HSCODE9031809090
USHSCODE9031808085
UPC
COOCHINA
Grove - SEN54 All-in-one environmental sensor - VOC, RH, Temp, PM1.0/2.5/4/10 with proprietary algorithms, HVAC, Air Purifier
SKU 101021013
Grove SEN55(NOx, VOC, RH, Temp, PM1.0/2.5/4/10)
USD$49.00
